Hey everyone Im looking to replace a 6" 8ohm speaker on my vintage guitar amp but im having trouble finding a decent guitar speaker weber jensen.etc.... that is 8ohms there all 4ohm. I would really like to install a 8" or 10" but im a afraid that will hurt the collector value of the amp is this true?
Replacement speaker?
More info would help. For starters, WHAT AMP? Some models have an easily removable grill/baffle that allow you to retrofit a larger speaker without permanently modding anything. Another solution is to use another cabinet and rig a speaker line off your amp, which should be pretty painless.Don't believe everything you think. Beware of Rottweiler. Search engines are free.
I want to say that Jensen Mod 6" comes in 8 ohms.
Try AES:
Antique Electronic Supply
Search for:
P-A-MOD6-15-8
Have you considered making an 8" baffle? You could keep your orginal baffle for sake of "orginality". If you have a grill cloth that is close to orginal you can make a new baffle out of plywood, paint it, etc. It just depends on the size of the box.
Good reply Bill as always. I didn't see the 8ohm on jensen's website that's why I posted. Now the question is should i build a new baffle for a 8" or 10" or should i stick with the 6" anyone have any experience with the MOD 6"? the amp is loud enough but the speaker sound a little "cardboardish" and Id like to get some more bass response from it.
Pair of Vintage Fisher 6" Retro Instrument Speakers | eBay
Check these out. The price looked reasonable. I've gotten some decent vintage speakers on ebay. There are others there. I just typed 6" vintage speakers. There were also some Jensens.
As far as 8" go. they most likely will have better bass. I built a mini half stack with 2-8" celestions and 2-8" telefunkens and it is bassier than any of my cabinets. I run a 5 watt champ type build into it and it sounds great. It actually sounds great for bass guitar too.
Yep, they are very easy to haul around and the Celestions are rated at 75 watts and I don't know about the Telefunkens, but I've played a 20 watt amp into it pretty cranked and it handles it fine. I was amazed at the boom out of it. What did you think of the link? Were you looking for something newer?
