Polytone 101 Speaker Impedances
  • Polytone 101 Speaker Impedances
    Got a Polytone 101 Bass combo
    here. It has a 15" speaker and two 8" speakers all wired in parallel.
    All 3 speakers are dead and open circuit. No impedance markings on any of them.
    Anyone know what impedance they ought to be?
    Polytone power amps are typically designed for a 4 ohm load. My guess would be 8 ohm - 15 inch and 2 x 16 ohm - 8 inch.
      Bill - that was my guess too. Just wanted to see if anyone else guessed the same.
        You could always check the ratio of the OT. This would allow you to figure the primary Z at different speaker loads. The right load should become obvious as it relates to the circuit then. It's probably 4 ohms as noted but it's easy enough to check and be sure.
          Sadly it's a transistor amp
            OOOoohh... Gotcha. I've been here at the forum almost since it's inception. I forget that there's so many transistor threads here now since it really was a tube amp only sort of place for a very long time. With so many modern tube amps using transistors it was bound to happen of course. I'm just a dinosaur.
              I know exactly how you feel Chuck. I occasionally get people (young people) bringing me amps and saying "it's really old..." and it turns out to be a 20 year old transistor Fender.
              Still can't quite get my head around anything with transistors in it being "vintage" or "classic"....
