Firstly, I'd like to give an update on the 5E3 based project that I built & once again thank everyone on here who kindly gave helpful advice. I've now used the amp at several rehearsals including one in a rehearsal studio with (loud) full drumkit and at 2 small venues (100 capacity) and it's superb - the sound carries beautifully and there's plenty of body. At the first gig, I was approached by an electronics engineer who wanted to know everything about it. It holds its own against my Vox AC30 and 64 Tremolux. At low volume it has great clarity and definition. Its only failing is that it's no good for bass guitar - the sound is fuzzy and flabby. I suspect that this is because the top 2 speakers are probably not proper fullrange - they're a pair of Alnico 6" Wharfedales - I'm aiming for a 4x8 amp, but I had these 2 speakers so wanted to give them a try.
Secondly, I want to build a 5E3 (or 5E5) amp that will take either a pair of 6V6s or a pair of 6L6s - from the research I've done so far, the PTs and OTs are crucial - is it possible to use PTs and OTs that have enough 'slack' for both or is this just naive? - There are a few threads on here, but none seem to answer the question definitively
