Newby trying to learn about working on amps without killing myself, just acquired a '72 Traynor YBA-1.
Couple of questions:
- earlier versions originally had 4M A volume pots, and I've read it's recommended to change these out for 1M A pots. Mine has 500k Linear pots. What's recommended here (1) leave them as is, or (2) change them for audio pots @ what value?
- what's the story on speaker impedance - will I do any damage running non-8 ohm speaker setup (2 x 8 ohm in parallel or series, ie. 4 or 16 ohms) ?
- I noticed the caps were all drained a couple of days after operating the amp. Is this normal - were there draining resistors in the factory circuit - how would I recognize these if installed?
- what sort of MV would be recommend, pre or post PI?
Thanks a bunch
Thanks a bunch
