First off, a little backround on this amp.
About 2 years back a local craigslist ad had a '72 Champ for $200...I jumped on it.
Got there, and the amp looked like it was under a porch for the last 30 years easy...it worked, but had issues. I offered $150, and walked away with it for $175.
Ordered all the parts, good caps, carbon comp resistors, cloth wire, quality turret board, Weber alnico, put in a new OT even though the orginal worked. Built the amp, through in a 1959 RCA 12ax7, 1960 RCA VT107 (JAN 6V6), and a mid 60's NOS RCA 5Y3GT. Sounded phenominal. I restored the cab and hardware, and have enjoyed the amp ever since. I moved last June, and ever since the amp has sounded "off". I use it for recording, and has produced some killer tones...but I've struggled with recording it since I moved.
Starting with stock values I upped the cathode resistor to 640ohms from 470ohms...plate voltage was 420v, 12ax7 was seeing 285v on one side, 255v on the other.
Added resistors in series one by one to the first power drop until I got it down to 390v at the plate, added a resistor between the screen and the OT to drop the screen voltage just below the cathode voltage. Stock value for the 1st power drop resistor is 1K -1W...after I got done adding resistors: 6K!
So now it's idiling at .039 (which sounds high...but that's what it seemed to like. I was also able to better balance out the 12AX7 by changing resistor values on one side...once I got voltage down on v+ it settled at 259/253...it's not getting any better than that! It also aided in getting rid of the brightness that was over the top on my humbucker guitar.
Came out to: .0398 x (390-25.5)= 14.5071 watts
We watched my sister in law's newborns last night so they could go to a wedding...couldn't test the amp at volume until this afternoon (and BTW I don't miss having babies at night)!
Cranked it up this afternoon for a stress test; amp started smelling funky. Immediately turned it off and checked for hot spots...found nothing. Mostly worried about the power tranny because it's original, the OT is good, but in a box to bring the amp back to stock if I sell it someday.
I fooled around with the resistors on the 1st v drop again, and upped the bypass resistor value a touch.
Came up with 27V across the bypass at 743 ohms.
Biased: .036 x (402-27) = 13.5 watts
The extra voltage brightened up the amp, brought up the voltage of the 12ax7 to 265. With the brightness, it brought out the fizziness. Took the 2nd voltage drop (10K) and put in jumper resistors until I got the 12ax7 to 280 volts...fizziness gone.
Amp was still pretty bright, and got a bit brighter when I cleaned up the gain stage...the 12ax7 and the 6V6 both are balanced within 1 volt.
I removed the 15K resistor from the bass pot to ground, put in a 8K resistor to a 10K pot to ground to create a mid control. Helped a bunch to clean up the brighness and the amp is real smooth now. Still a little crisp in the treble department, but I think I can change cap values in the tone circuit to play with the Q.
I've learned more about this amp in the past few days than I had in the 2 years I've owned it. Which is good, because I'm going to build an ultralinear version of the princeton reverb soon...and the experience is really helping my confidence about it!
I have to stress the importance of being safe while you are doing this though.
I got zapped in the process...and I'm fairly seasoned messing with tube amps.
I was taking off my guitar and reached over to turn off the amp (which is just the chassis on my bench). Got zapped BIG TIME...the guitar I was holding literally flew out of my hands...and slammed down on a tile floor. Fortunately I was OK other than the pins and needles feeling in my forearms...and somehow my guitar wasn't damaged other than a scuff on the headstock.
I would really appreciate if anyone would share their bias challenges and outcomes on the Champ circuit. While I was doing this, I found enough info out there on it, but it was very scattered; which took a long time to sort out and apply. Be nice for future reference if this thread can help someone.
