I've had my Tremolux for over 20 years and used it regularly for gigs and rehearsals.
It's been re-capped and revalved.
It started smoking the other week, with guitar going through one channel and vocals through the other.
I've built my own 5E3 based amp recently so I have a basic idea what to look for.
Inside there's an acrid burning stench which seems maximum around the PT
All the caps looked fine. All the transformer coils and resistors had continuity. The B+ was 348v and the 6L6s had been replaced with Sovek 5881s.
The tube rectifier had been replaced with solid state and there's no standby mod.
The choke had been replaced with a 100 ohm resistor.
The PT although circa 1960 with paper bobbin was not original.
The OT is a modern replacement.
I decided to restore it to original spec with the following:
Full set of Hammond Transformers including choke:
Mullard GZ34 rectifier.
Pair of Russian military grade 6L6s.
I switched on with the DMM hooked up to measure the B+ which was 410v.
Once the rectifier warmed up, the amp gave out a rhythmic high pitched oscillating sound so I unplugged it straight away and decided to take it to the repairman who I've been using for years.
Sadly, he's retired and there's no-one else local so I'm going to have another go.
I suspect that the older components may not like the new higher voltages.
I'm going to replace the few older caps and check all the resistors for drift.
Specific questions:
1. Does anyone have any tips on what else I should be specifically looking for?
2. What is the best method to bias this model? - I've been studying some of the blackface circuits with bias pots and I'm confused because on the 6G9-B the equivalent wire seems to lead directly to the tremelo intensity pot - if I insert a bias pot where is the best place to put it?
Thanks in advance
Stephen
Specific questions:
Thanks in advance
Stephen
