Hello,
I've been working on a G6162 amp for over a year trying to bring it back to life. This amp is vertically laid out with 2-10" speakers and the power/preamp chassis above, not the one with the power section in the bottom and the preamp above. The tube layout is 5U4, 2-6973, 5-12AX7. I've done the following:
1. replaced the 3 cap cans
2. replaced the electrolytic caps(35/50v)
3. replaced out of tolerance caps and resistors
4. resoldered most connections new input jacks
5. new tubes, came without any
I have the amp up and running but have very weak channel 2 (reverb/trem).
Connected to a scope I have the following:
1. Channel 1: nice strong sine wave with slight drop between high and low gain inputs
2. Channel 2: very weak sine wave with almost no wave on the low gain input.
3. When I turn on the tremolo at the pot switch I get no oscillation at all.
4. When I turn on the reverb at the pot switch I see the weak sine wave drop to almos a flat line as I turn up the reverb.
At this point I've reached a dead end and don't know how to try and troubleshoot this issue. Any help would save me from pulling the rest of my hair out.
I'll attach a schematic with my voltage reading written in and a gut shot of the chassis.
Thanks in advance!
Davegretsch g6162001.pdf
Thanks in advance!
