I am in the process of fixing up an old 60's Ampeg Reverberocket II combo amp that had had a broken fuse holder and had not been played in a few years. I gave it a deep cleaning including the tolex, input jacks, pin sockets, tube pins, etc..., installed a new fuse holder, and fired it back up. The tremolo works just fine but the echo or reverb is not heard even when turned all the way up.
Here is what I have checked so far:
RCA cables tested good
Reverb tank tested good on both sides (168ohms + 184Ohms)
When I bump the tank while the amp is on I can hear the springs crashing around so I assume the recovery side of the circuit is good and the drive side is suspect
I also briefly unplugged the output side of the RCA cable while the amp was on and touched the center lug and heard a loud hum / buzz as I should.
Tested all pins on the 6U10 back to the circuit board for continuity - Unable to test this 12 pin tube on my tube tester
I opened up the footswitch and tested them back to inside the amp and they appear to be working
I also ohmed out the echo potentiometer and it appears to be good as well.
Then I started looking for drift in any of the resistors tied to the 6U10 tube. I noticed that I am not able to get a reading from the 10K wire-wound resistor that comes off pin 10 of the 6U10 (SEE attached photo at bottom). I did try alligator clipping in a new 10K 5W resistor just to test it, but it did not seem to make any difference. I would assume though that if it took out the 10K resistor it probably took out the .47 and/or the .02 capacitor that is tied to it, but I do not have a capacitor tester.
I am currently ordering a new 6U10 triple triode to swap in and see if that fixes it.
So my questions are:
What is the wattage of the 10,000 Ohm Milwaukee wire-wound resistor that comes off pin 10 of the 6U10? Is it a 10Watt or higher?
Would you suggest that I swap out that resistor and two adjacent caps and try it then?
Is there something else that caused these parts to go bad that I should be checking first before blowing new parts?
Any suggestions, tips or something else that I should be checking?
