I got a 1966 bassman off ebay. The seller clamed it worked just fine and that it was all original except for the addition of a 3 prong cord and the tubes were brand new. Well… This wasn’t the case.
One of my big concerns is that the bass tone knob on the guitar side doesn’t do anything and the bass tone knob on the bass side does almost nothing. I tested the pots with my multi-meter and they give me the correct readings so I was wondering if anybody know what I might need to check next.
My second concern is that I can see that some parts have been taken out. There 2 wires each of them runs from pin 3 of the 6l6GC tubes and then runs through a 220 resistor before connecting to the circuit board. Because I don’t really know how to explain it, here is a pic of the layout with the area circled where the resistors are missing.
So what I need to know is what this mod did. Is it something that I should change back? Or should I leave it alone? Will changing it back hurt anything?
My last concern is that the 3 prong plug was added but the ground switch was not disconnected. Should I disconnect the ground switch or just leave it the way it is?
