Hey all,
I've been poking at an old project again, a Stromberg-Carlson AU-36B from ~1952. Here's a schematic:
http://4.bp.blogspot.com/-fpBxYORLvg...orrections.gif
My amp is slightly different from the only image I can find online so I noted the differences in red. There is a schematic stuck to the inside of the amp, but getting a good picture of it is really tricky.
I'm in the process of recapping it - the PT is putting out 410-0-410 with modern line voltages so unloaded B+ is roughly 540V after the paralleled 5U4Gs. The schematic shows a plate voltage of 420V, so I'm expecting my loaded B+ to be around 470V. It's back-biased, so there's plenty of series resistance to keep the rectifier tubes happy. I have put protection diodes on each 5U4G; fusing to come soon. This iron's been around for half a century; I'd like to keep it for another!
Now my question is about that 5k/40W resistor to ground right at the screen supply. This schematic specifies 6L6 power tubes, and the schematic inside my amp specifies 6L6G tubes. Pins 1 and 8 have been tied together, so I'm thinking they were anticipating the possibility of a customer installing metal-envelope 6L6 tubes.
Given that, it's understandable why they'd want to bring the screen voltage down. (schematic in my amp calls for 350V on the screens). But does this still make sense with a quad of 6L6GCs? I figure constantly dumping a fair amount of current will help stabilize the bias, and I certainly don't need to make any more power, but if I don't need to be baking a cake inside the chassis I'd rather not do so. The preamp dropping chain would have to be adjusted, of course.
Oh yeah, and the OT appears to have a primary impedance of 4.4k. The photofact for the "AU-36" (not "-36B") specifies a 2.7k Raa.
So: let sleeping dogs lie, or remove the space heater?
