I'll say right off, I'm not an Amp or Guitar repair kinda guy but if I have to be, I will. The other day I saw this sitting
out by the road and new I had a little rarity. I asked about it. It indeed was going to be trashed so I took it home. First thing I did was look online for this brand that I'd never heard of...Noble. I found this forum and the only link or pic online of this model...here. Turns out this seems to be a 1965 Noble Peerless 323 (made by Magnatone). I got the year because it seems there's a history webpage dedicated to Magnatone Amps and its states that in 1965, Magnatone switched to Jensen speakers. As you can see, by the speaker pic below this most likely was the first year they produced this model with a Jensen speaker. Also, It has the date stamped inside where the electronics are. The year is faint but I loaded a pic up of it in Paint.Net and did some trickery and it looks like the year 1965.
The pix below are in the condition I found it in and as you'll see...the inside is stunning. It all works...with a few quirks.
I first checked the fuse and it looked good so I plugged it in and the light came on. About 45 secs later it came to life. All the tubes glowed and a familiar hum and sound came around, Potentiometer gagging. I plugged my guitar
into it and it works but any knob position was hell to keep quiet. I've never had to clean out or clean up and amp or guitar so I went about online and i found a product everyone seems to use called Deoxit. I followed the directions and it has fixed the knob issues. All the knobs can now be turned without a single noise or scratching sound. All the inputs have the same issue in that you have to rotate the input cord just right or you'll blow your ear drums out. This is one part I haven't done yet. I'm fretting about replacing the original anything in this thing. It's all stock it seems. I haven't found a simple solution for the input jacks like I did for the pots...BTW..The footswitch and tremolo system work fine also...no problems.
Unfortunately the original speaker seems to have a few small age holes in it. I can't tell what kind of difference this will make but I'm going to leave it as it is. When I play through it, anything above 4 I'd say starts to have that tearing or vibrating sound. Anything below that it sounds fine.
Surprisingly, the schematic for this model was on the backside of the protective plate. As you can see, about 20% of it has weathered away but I thought something is better than nothing so here's a pic for reference.
I'm posting this mainly for reference to anyone out there who may have one of these and is stumped as to what it could be. Also as a reference for repair. I need to know what a fix could be for the input jacks, what glue I could use to but the rubber backing back on the original foot switch and if I should have the speaker redone or just get another speaker to replace it.
Apologies if this is the wrong place to post this but it's my first time in here.
Not bad for something someone was going to throw away eh?
PS....I have loads more pics to show...close ups of the pots...resistors or whatever else if wanted.
