I have a GA19rvt Falcon Crestline on the bench. it uses 3-6EU6's a 6C4, 2-6V6's and a 5Y3. I have worked on several of these amps and also a Epiphone EA28rvt that has the same circuit.
This amp is different because it has an aluminum chassis! It also came to me in pieces and on inspection it was pretty much untouched inside, but the reverb transformer had the wires cut on top of the chassis before they went thru inside. The transformer tested open and I'm not surprised as the wires in these are like hairs and most break if they are pulled on at all.
I've gone thru the amp and replaced the electrolytic caps and power resistors and such and it sounds great. I had an extra fender reverb transformer that I installed and still can't get reverb to work. I can connect speaker to the transformer, pull the power tubes and play a guitar thru the speaker, controlling the volume using the reverb control. I've replaced the rca cord from the recovery side with a new cord but no go. NOTE: I am using a fender reverb tank to go with the new transformer.
I'm hoping someone can point me in a direction to troubleshoot this issue.
I've got my working Falcon chassis on the bench next to this one and, everything seems connected properly. I've subbed my working Falcon tubes in place of the others with out any affect.
Any help would be great. The attached schematic is for a Pathfinder but it is exactly the same circuit.
Dave
epiphone-ea-28rvt-pathfinder-amplifier-schematic.pdf
Dave
