Okay, I know I've seen this discussed before, but my memory is crapping out so I need a refresher. My Princeton has the extention speaker jack. Stock speaker is 8 ohms, and plugging in an extention speaker runs that speaker parallel and would put a 4 ohm load on the output tranny (assuming the extention speaker was also 8 ohms). I'm certain I've read (may O'Conner's book?) that Fender's transformer can hold up to this "mismatch" with no harm to the OPT or tubes.
Using that logic, I should be able to use my 4 ohm Celestion 30 in my combo as a single speaker. This is counter intuitive to my understanding of OP trannys, but that doesn't mean it can't be done. Why else would Fender have put the extention jack in?
