Magnatone Varsity M-197-3-V
You say you want to get the amp to stop distorting. Is this something that it started doing, or are you just trying to bring it back to stock performance? I have amps like this and they will only play clean at low volume.Now Trending: China has found a way to turn stupidity into money!
They are using pin 6 of the 6v6 socket as a tie point. The disc cap is basically wired directly across the primary of the output transformer. The 1K resistor connects the output from the rectifier to the primary of the OT and to the first filter cap.
