Back in the 1970's certain amps had exposed power transistors with the +/- rail voltages on the case of the transistor.
By the late 1970's, Peavey put the black transistor covers in the early Mark III Bass amps before moving them
inside the amp and adding the large heat sink on the back of the amp. (see picture)
The particular amp is a Marshall 2098. It had the exposed power transistors. (see picture)
I was thinking of putting the nylon/plastic T03 covers over the two output transistors for safety.
The entire back of the amp is a heat sink (fairly large area).
Would this trap the heat and cause the transistors to fail?
Would you recommend adding the transistor covers to this amp?
Any thoughts (heat vs safety)?
Thanks
Thanks
