I acquired a silver face Champ a couple of years ago. There must have been an apartment cleanout because it was sitting beside the dumpster. The amp looks to be original inside but the speaker is missing. Actually there was a speaker laying in the cabinet but it is a Realistic brand so it goes in the junk box. I trained on tubes back in the 70s, worked at Crown on audio amps for several years, and have worked on tube ham radios so I am not totally clueless as to the work ahead of me. I would like to restore it to a good working amp and maybe make a couple of dollars for my effort. I do have a scope, signal generator, dummy load, Variac, and hiZ voltmeter. I haven't powered anything yet and don't intend to until I'm sure nothing else will smoke.
That said, here are the issues and questions.
What speaker?
The Tolex is in good shape, no rips. Grill cloth has a small snag.
Burned resistor--The cathode resistor for the 6V6 is cracked and toasted so the magic smoke is out of it. White plastic Malory cap next to it has a melted spot. Also the 1k 1W resistor in the power supply is open and looks burned.
Line cord--The line cord is a heavy 3-wire SJO type cord with an unpolarized 2-wire plug. The soldering inside of the amp looks good but something is doesn't feel right. Did this amp have a 2-wire cord? The death cap is still in place.
Power electrolytic-The schematic AA764 seems to match the amp except it calls for a 20,20,20 mF Malory cap. The amp has a 40,20,20. If the cap was replaced it was an excellent job of soldering. Is this a case of documentation not catching up with production changes?
Bass pot broken off and knob is missing.
I have tracked down some of the parts. Any suggestions and hints will be appreciated even if the suggestion is to sell it as a parts amp.
What speaker?
