So, I've got this Johnson Monarch M-4, which is a loose Canadian clone of the 5D8 Fender Twin.
Plugged straight in to the wall, the B+ is stupidly high (500V.) Original filter can cap was rated @500V, I replaced with a 525V cap. I would like to sell the amp, and while I can run it on a variac to get the B+ in line, I can't count on whoever I sell it to having the knowledge to do that, and I want to sell a reliable amp, not a time bomb. I'm using NOS 5Y3 recto tubes (it uses 2 in parallel.) A 250 ohm sag resistor at the PT centertap brings the B+ down to 432V, which is still really high. I'd really like to see something like 370-400V.
I bought a stud mount 39V/25W zener from Weber which for some reason only drops the B+ only about 10V when installed in the CT ground leg.
Ultimately the power transformer seems to be way overwound for this application. I don't want to make the supply too saggy by introducing tons of resistance. 5Y3s are pretty saggy to begin with...
Any ideas for the best way to fix this beast?
Nathan
Nathan
