Need Help Identifying This One
Looking at the tube numbers I'd guess that the filaments are wired in series to 110vac. FWIW the tolex reminds me of Silvertone amps.The Blue Guitar
www.blueguitar.org
Some recordings:
So, I pulled the guts out of the amp and I found this hand written information inside:
I searched around and found an amp called the Lindell Tremolo Deluxe that looks like a variation of the amp I have. It has the same panel layout and the width and depth dimensions are a match.
Now if I could just find a schematic.
Be aware this is what is referred to as a "widow maker" amp and is not considered safe to use without the installation of an isolation transformer.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by Steve A. View PostLooking at the tube numbers I'd guess that the filaments are wired in series to 110vac......."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
If the filaments are on the PT secondary like that then you are fine.
If memory serves, sometimes they have a PT but run the series filaments directly off the line, which I still consider a safety issue, even if it's not exactly a widow maker.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Nope, 200V plate & 10W dissipation... 35L6 is similar...
Piggers.
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Originally posted by Justin Thomas View PostNope, 200V plate & 10W dissipation... 35L6 is similar...
Piggers.
Justin
Thanks for all the great advice!
I have been considering adding a 6.3V transformer and switching to all 6V tubes (6x5GT, 6AV6, 6AU6 and 6W6GT). That way, the existing power transformer would take care of isolating the B+ voltage and the added 6.3V tranny would do the same for the heaters.
Of course I'll still add a fuse and change the cord to a three prong.
I took a shot at drawing up a schematic of the amp (I used Paint). It's a work in progress and I hope to finish it in the next couple days.
Here's a peek:
You still have to add a transformer, then change all the tubes over.
Why not just add an isolation transformer and run the entire amp off that?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostYou still have to add a transformer, then change all the tubes over.
How big of an isolation transformer would I need if I did just add one to drive the amp?
Thanks,
Joe Y
Well, if you have all the parts you need, then that's different.
I think a 50VA unit like the triad N-68X would be more than sufficient.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
