A couple of months ago I chanced upon this chassis that had long been removed from the original cab. The chassis and trannies date to late-ish October 1973, and the internals have been well and truly butchered by past owners. There are bits of assorted off-board jumping (to avoid the pitfalls of the SF waxed board), someone added a bias bucking transfomer at some stage, the lamp was disconnected, and there was evidence of a tube blowout in one of the output tube sockets (charred 1R bias measuring resistor) - yet the filter caps were still original (go-figure!?). Someone put a PPIMV mod in at some stage. Someone added a funky bias pot. So I acquired it (I must say for very little money) for the purpose of fixing it up - in case I run out of things to do with the rest of my life.
The 100W MV Quad Reverb, Dual Showman Reverb, Twin Reverb, Bassman Reverb, Vibrasonic Reverb and Super Six Reverb from this era are basically identical amps except for some variations in the output transformers and speaker configurations (but the dual showman, twin and quad reverbs from this era even have identical OTs).
Seeing as how its been extensively butchered already, and as its effectively beyond my abilities to locate an original 4 x 12" cab complete with speakers in this neck of the woods, my plan has been to get it fitted into a head cab to go with my mid-70s Dual Showman Reverb cab.
With pre-amp tubes installed, the PT secondaries deliver 360-0-360VAC and 6.4VAC, and the (modified) bias supply range is -27 to -59VDC (I will eventually change the funky bias pot setup back to something more appropriate, that has less adjustment range). The OT tests good for Pr:Sec VAC ratio and delivers an impedance ratio of 631:1 (2k5 with 4R speakers). I may yet have to replace the PT - time will tell (once I get around to shoving some 6L6s in).
So far I've done all the e-caps, replaced the output tube sockets (while trying to keep all the old wiring), replaced the lamp holder and reconnected it, cleaned out around the power amp end of the chassis with isopropyl, and tolexed up a little head cab for it. I'm still hunting for about 6 witchhats (as some previous owners have lost these along the way).
Seeing as how there's extensive evidence of previous patch-up jobs to get around the waxy-board syndrome, I'm inclined to eventually remove the main board completely and 'blackface' that part of the amp.
Thought I'd leave a progress blog here.
