I have a Valco 51 amplifier for repair. Thanks to the forum I've correctly identified the amp., but this is the first time I've come across this use of a field coil on the speaker.
One of the issues is a dominant low level hum which remains present when the volume is turned right down.
I'm beginning to suspect the circuit involving the field coil.
One side of the voice coil is shown on the schematic to be connected to earth, but this is absent on the amp.
The connections to the field coil are clear to understand but there is also a pair of wires (another winding?) coming from the top of the field coil and connected only on one side to the voice coil.
There appears to have been work done replacing caps, on this amp, and some resoldering of the speaker and field coil connections at the amp, so I don't know if there is a mis-wire?
