I'm getting a crazy annoying and loud squeal when I turn the volume knob up. I've gone thru the amp and have new caps. Would this problem most likely be a tube or the volume pot? If the pot, how do I test it?
'62 Kay 503A Volume Squeal
Is this one of those (tube) amps where you need to make sure the speaker is grounded to the chassis? I remember having a similar problem with an old Gibson Ranger amp. There were two leads coming off the output transformer going to the speaker. But because there was no speaker jack connected to the chassis, I had to run an extra wire from the speaker (-) to the chassis ground.It's not just an amp, it's an adventure!
Originally posted by Perkinsman View PostI doubt its a ground issue since it is intermittent, which I should have mentioned. I'll test all the tubes tomorrow and go from there.Last edited by Chuck H; 08-04-2019, 02:22 PM."Take two placebos, works twice as well." Enzo
Originally posted by TomCarlos View PostIs this one of those (tube) amps where you need to make sure the speaker is grounded to the chassis? I remember having a similar problem with an old Gibson Ranger amp. There were two leads coming off the output transformer going to the speaker. But because there was no speaker jack connected to the chassis, I had to run an extra wire from the speaker (-) to the chassis ground.
Originally posted by Perkinsman View PostAs you can see in the pic, there are 2 (blue & red) leads from the OT to the tubes. There is an odd grey lead that runs from the speaker frame to the amp chassis.
It is slightly wrapped around blue & red wire to form a kind of shielded cable.It's All Over Now
Originally posted by vintagekiki View PostThe fastest way is to temporarily replace the pot with a pot that you know is correct.
Check condition R7/ 3M9 and C3/ .05
I replaced R7 & C3, still squeals when volume is over 6-7. What is 3M9?
I attached the schematic, btw, this is a 504 model, not a 503a as I originally posted. My bad.
Originally posted by Perkinsman View PostCan I use any size pot or does it have to be same as volume, 1/2 meg?
https://el34world.com/charts/Schematics/files/Kay/Kay503a_1962.jpg
The values for R7 & C3 refer to the Kay 503A schematics; 3M9 = 3.9Meg
Kay 504
Volume pot between 1/2 Meg to 1 Meg
I assume there are new tubes in the Kay 504 during repair.
Check condition C1 (20 + 20 + 40)
Between R8 and R13 parallel to C1 (20) R8 and R13 parallel to C1 (20) temporarily connect 22uF/ 400VIt's All Over Now
Kay 504
Originally posted by vintagekiki View PostMost likely to oxidize the ground from input 1.
Clean the chassis below input 1 and replace jack.
Success!! I took the jack off, clean the chassis, used a little emory cloth on the part that makes contact with the tip of the jack and emory cloth'd the inside of the jack. Then used contact cleaner on the parts and Voila!
Now all 3 of the jacks work, pots are all cleaned, filter caps replaced with fresh stock and a few smaller caps. Amp sounds great at 10, tremolo is very sweet too.
Big thanks to Vintagekiki!
