Something completely different came my way. I think this is something very few will have seen. I haven't got a full set of pics yet, but I'll add when I have it back together. I know the name of the manufacturer but not the model. I've hidden the name for now just so you can have fun making a guess or two. 2 EL34 2, 2x ECC83.
I had started to dismantle it before I took any pics so these will have to do for now. This is the most original guitar amp Ive ever worked on in several ways.
First this is top top with the cover off. You can see the sides are two aluminum extrusions and the chassis drops in from the top, tubes first.
Here I've taken it apart some more. Complete disassembly was necessitated by the silicone adhesive which held it all together. I could not get the glued-in chassis out without doing this.
Here is the chassis top. Note the smoke marks around the EL34 socket over where the PCB had arced. You can just about see the side of the front panel with cooker style knobs. I swear when it's all together it looks more like a portable heater than a guitar amp.
and the fried PCB
All the controls use switches instead of pots so I just had to reverse engineer the schematic for curiosity and prosperity.
Clearer schematic pdf:
Schematic.pdf
Much to discuss on this design both mechanical and circuit wise...later.
So have you guessed the name and manufacturer yet?
and the fried PCB
Schematic.pdf
