Voice of Music Amp - VM 160
  • Voice of Music Amp - VM 160
    Ok. I know I have a problem. The first step to recovery is to admit the problem. I'm a vintage tube amp addict! Here is my latest acquisition. Appears to be about 1952 Voice of Music Model 160 amp. Its not a guitar amp, but it looks like a good candidate. Here are the pics as it arrived.
ID:	876273 Click image for larger version
ID:	876274 Click image for larger version
    More pics.
ID:	856554 Click image for larger version
ID:	856555 Click image for larger version
      Could make a guitar amp with some mods.
      Schematic:
        Schematic:
        [ATTACH=CONFIG]56739[/ATTACH]
        Thanks for the schematic! Besides replacing the input jacks with 1/4", what mods would you suggest?
          I'd cascade the mic input through a tone stack and then to the phono input. Maybe add a cathode bypass cap to to mic input for less hum and more gain. Also add a further RC filter stage in the power supply to feed the mic input.
            FWIW I built a little 2x6v6 amp from the guts of a VOM phonograph. It sounded remarkably better than you might expect from the 300Vp and that tiny OT. It actually had a great low end and literally perfect , classic, definition of the model BF Fender clean tone. And because of the low-ish plate voltage it would move very gracefully into thick, cello like clipping. The cabinet I made for it was pretty crappy and I'd built the rest of the circuit from scrap components PTP and all squeezed into the tiny chassis. So I decided to tear it down for a proper build of the same circuit some time. So I still have the transformers. My PT is a stand up whereas yours is a lay down (Z mount?). But the OT looks like the same one I have. I don't think you'll be disappointed
            "Being born on third base and thinking that you must have hit a triple is pure delusion!" Steve A
              That's what I'm thinking. The cabinet on this one looks pretty decent. Its cleaning up real nice. I really like the way the amp chassis slide out and can sit on the side. Very cool.
                Heres the underside of the chassis. Comes with a schematic too!
ID:	856578 Click image for larger version
                  The schematic looks good but hard to see. Do you have a scanner? My printers are also scanners, for example. A pdf scan might be easier to work with. Unless it is the same as the one posted up in post #3?
                  It looks like someone already replaced a filter cap, but that orange one has a date code of 1973, so evven it is getting old. meanwhile I would be surprised if all those paper caps didn't need replacement. Probably leaky by now. Note the resistors are all 20%, and even then likely drifted, but frankly that probably doesn't matter much. Just don't expect a "100k" resistor to measure 100k.
                  But looks good and clean.
                    What looks like a Sprague black tubular capacitor would not be original either if the amp is from the early 1950s.
                    At this point in history, it's not unusual to be doing a 2nd refurbishment of amps from this era.
                      Here is a scan of the schematic. Not much better though.
                      VM160.pdf
                        The can cap and the sprague look like replacements. The values are also double of the schematic values. 40mf instead of 20.
                          You're right, not much better. But a have to say thanks for doing it.
                            Ok. One more time. This time I took a pic of the schematic with a better camera.
                              [ATTACH=CONFIG]56768[/ATTACH]
                              Picture seems a bit dark so lighted it up a tad.
