Precision Electronics Amplifier question
1950's audio amp.
This amplifier was converted to a guitar amp. It's 10w and uses a 6X5GT for the rec, 12ax7 pre and a 6l6gb for the output tube. The sound is ok but it's a bit bright and lacks headroom. I'd like to do some tone cap changes to darken it up a bit. There is a bit too much sag as well. It is a class A amp. Correct me if I'm wrong, a SS rectifier in this situation will not help the sag as the output tube is running close to max all the time. A SS rect will also put out more VDC, where the 6L6 may not be able to handle it. So what part of the circuitry of class A amps determines more or less sag? I've yet to fire it up to test voltages, just got it in. I do see the filter caps are original. Perhaps raising the the values would give me more headroom as well?
Thank you,
Gary
1950's audio amp.
Thank you,
Gary
