First time inside an amp. Several months ago I replaced all tubes with new old stock american made tubes such sylvania, phillips JAN etc, seven 25uf/25volt caps, the bias cap back to factory specs with a 47/100v and resoldered three corroded pot connections.
THe 6l6's were sylv. matched quad marked 38. The bias was a snap to reset to the 38.
When first plugged the amp made some strange loud sounds, I found the reasaon was the bias cap replacement. For some reason the non-factory spec bias cap was the culprit. I put the bias cap I took out back back in the amp.
To my amazement the amp preformed way above my expectations, not the slightest hum, the clear channel bright and clear and the distortion outrageous.
Its my teen daughter amp and after about two weeks of hard use, she told me the amp was loosing volume and after about a week quit all together. I have the back cover off and when I power up the amp, I get a very dim glow only the farthest left power tube . all other tubes are dead.
I am limited in the test equipment department. Have multimeter and homemade bias checker.
Can anyone give me some information on what is faulty in the amp? Or where to start troubleshooting to pinpoint the problem?
Thanks
Conky
I see the asking prices for these original twin on E-bay are outragous. Possibly for economic reasons alot of folks are black facing the silver face amps.
A local pawn shop in the seedy part of town in Northern California has a original 66 Fender twin reverb for sale. Tolex not bad shape, grill cloth replaced hash job, but lots of extra material wrapped around the speaker board. Has replacement foreign tubes and appears or may have a replacement back chassis panel. Overall alot better shape than the amp I started with. I have the serial number, asking price 1695.00, may be negotiable. They told me its been in the window a long while.
Thanks
Conky
