Found a 1962 Gibson GA-79RVT
  • Found a 1962 Gibson GA-79RVT
    A young guy at work told me his dad had an old Gibson amp in the attic that hadn't worked in years and almost
    caught on fire last time it was plugged in. When he described it and said it was kind of wedge shaped I tried to
    act disinterested.
    A couple weeks later I bought it for $100
    The upper 200Ω 10W resistor and 25F capacitor were burnt to ash and the power supply choke smoked.
    I replaced those parts and totally rebuilt and rewired the power supply.
    Next power up the resistor burnt and the new cap exploded.
    THEN I realized the 7199 phase inverter tube had been replaced with a 12AX7 with no rewiring of the tube
    socket. Bought a 7199 tube and all or the other eight tubes and the next power up was much more successful
    but a lot of loud hum.
    More investigation showed the earlier tech had replaced the original 20/20 450V audio cap with a single
    40F cap and combined the circuits. I replaced that with two new 20F 450V caps on separate circuits.
    22 days after purchase and $380 in parts later I have a vintage tube amp that sounds like a 1960s amp
    is supposed to with no noticeable background hum buzz or hiss.
    This could be my highest profit turnover ever.
    I don't see that happening.
    Being they only made about 1132 of this model I'm thinking this one is keeper
    Picture red arrows point out the bad or failing parts. Other picture is the repaired chassis.
    I think I'll leave the tolex and grill cloth just as it it.
    I'm two years older than this amp and that look just fits me!
ID:	907154 Click image for larger version
ID:	907155 Click image for larger version
    Many of life's greatest adventures begin with the same four words:
    HERE, HOLD MY BEER
    How did you spend $380 in parts? Seems high, Unless you had a choke professionally wound to original specs.
      He mentioned a re-tube. Maybe NOS?
        Tubes were the majority of cost.
        The 7199 was a little over $70 and the the three 6EU7s totaled $77
        It does add up quickly.
        HERE, HOLD MY BEER
          Wow. Last 7199 i bought 2 years ago was $20, RCA brand new in the box. 6eu7 not sure on the price. You could have bought the 6gh8 adapter and rewired the 6eu7 for 12ax7. Does that model have the field coil speaker? I had a GA75 way back when.
            Great find and well done!
            I’m perplexed why a light bulb limiter wasn’t used to bring fault current down to safe levels when powering it up, especially when warned it smoked the last time it was used?
              Wish I could fine them for that price.
              I did consider the 6gh8 adapter but wanted to keep is as original as possible.
              HERE, HOLD MY BEER
                Certainly should have but didn't.
                Several years ago I refurbished a 1978 Fender Deluxe Reverb. Smoked components in it too on first power up.
                I'm thinking a Variac may be added to my bench if I find another project.
                HERE, HOLD MY BEER
                  My variac is a little used boat anchor, whereas my light bulb limiter ranks about#2 item of useful things. Not up there with a multimeter, but in terms of earning its keep / bench space / avoiding magic smoke release, to not have one seems remiss.
                    I had built one many years ago. No idea what ever happened to it.
                    Maybe time to build a new one.
                    I do get lax sometimes.
                    Just like I'm constantly preaching the hazards filter caps, yet I still get the occasional knuckle numbing myself
                    from not discharging the caps.
                    I know better.
                    HERE, HOLD MY BEER
                      act disinterested.
                      I remember this amp, having seen one at Saul Benton's shop in Hollywood back in the mid-60's. Back in the era of Gibson's Titan and Mercury series amp/cabinets, and around when the Firebird and Thuderbird came out. Very cool amp.
