This has come to me for some work. As I understand it only 100 of these were made for Ibanez by Laney. I thought some might be interested or just to document for posterity, here are some pics and a schematic that I drew up. The preamp is rather unusual in that the tone stack is last in chain. This means that even the clean channel has rather a lot of gain. The final clean stage V2A is heavily loaded by the gain pot and the tone stack and can only manage about 70Vpp out. I tried a 12AT7 and was able to get that to 90Vpp. Also, the use of highish voltage transistors to do the reverb and final mix / buffer is not something you see every day.
There is heavy negative feedback around the power amp which means the clean channel cannot provide sufficient drive to get clean to full power out.
Starfire VT50.pdf
Starfire VT50.pdf
