1st thing I notice is it has a 3 prong cord, black wire to fuse, white wire to switch, green wire soldered to chassis. If that is correct wiring, what's a good place to start checking? Thanks.
'65 Fender Champ No Power
Those Voltages seem like the amp should be working except pin 8 of the 6V6 seems high. With the power OFF, check the resistance to ground on pin 8. Might give a funny reading depending on your meter, but should settle down to something around 470 Ohms.
Have you tried an external speaker ?WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
I think the voltages look extremely high. Even the higher voltage silver face Champs only run about 420Vp with 120V wall outlets. In '65 the Champ is only supposed to have about 350Vp. So it would be a bit higher today, but certainly not 450Vp. No way you can center bias for class A at that voltage with a 6V6.Last edited by Chuck H; 04-02-2022, 03:24 PM."Take two placebos, works twice as well." Enzo
- Likes 1
Originally posted by loudthud View PostThose Voltages seem like the amp should be working except pin 8 of the 6V6 seems high. With the power OFF, check the resistance to ground on pin 8. Might give a funny reading depending on your meter, but should settle down to something around 470 Ohms.
Have you tried an external speaker ?1 Photo
Replace the resistor from 6V6 pin 8 to ground. Usually 470 Ohm 1 or 2 Watt.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Looks like just normal glow from the filament. No glow from the grey plate structures. The little spec of orange on the 6V6 looks like just a refection.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
