I just couldn't resist! Late 30s Lectrolab Model 20. 8" field coil speaker. Hope it's still good. Tubes are 80 rectifier, 6F6 power, and 6SJ7 preamp. Nice solid cabinet measures 11"×11"x5.5". Cool paint, bakelite handle, and fancy speaker cut-out. I didn't see much info on. It's all dusty and original just the way I like!
Vintage Lectrolab Model 20 Tube Amp
I just couldn't resist! Late 30s Lectrolab Model 20. 8" field coil speaker. Hope it's still good. Tubes are 80 rectifier, 6F6 power, and 6SJ7 preamp. Nice solid cabinet measures 11"×11"x5.5". Cool paint, bakelite handle, and fancy speaker cut-out. I didn't see much info on. It's all dusty and original just the way I like!Tags: None
- Likes 2
Is that finish cracking original or is it the footprint of Father Time ? It looks so cool, I wouldn't think it was original as old as the amp is.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by 52 Bill View PostI've seen that finish before, I think that it is all original. Great find! Looks a lot like early National/Valco/Supro construction. It's also before they started using Homosote for the cabinets.I never would have known the original name of that product.
- Likes 1
That power transformer has enough oxide that it's scaling. As long as it works well and doesn't get too hot you should probably remove whatever rust you can from the laminates with as little abrasion as practical and then spray it with some Rustoleum to slow the roll on that damage. Fortunately it's black now so you can do whatever you need to the end bells with little consequence since it would be repainted. I usually remove the end bells and spray those and the laminate/coil parts separate. It stinks a bit for the first dozen operations or so but I like to think it's a more thorough job of mitigating further oxidation.Last edited by Chuck H; 02-23-2023, 12:30 AM."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostThat power transformer has enough oxide that it's scaling.
Plenty of field coil speakers had dust caps. Though it's not uncommon that they either didn't (or at least currently don't***) or just had a minimal sort of cover. There's no harm in adding one.
*** Since field coil speakers are typically an older design AND the amps made to work with them don't work without them (so the speaker must remain in sevice rather than be replaced) and those older designs commonly used hide glue (which gets more brittle with age) what we see in on line images may be a disproportionate number of missing dust caps rather than speakers that never had them. But it's hard to say.
I can't imagine the "tone" would be detrimented in any way and keeping dust out of the rare and irreplacable speakers voice coil mechanism would be the point."Take two placebos, works twice as well." Enzo
- Likes 1
Anything is possible and I'd say, if you think there's a chance you could "screw it up", probably best to leave it alone. If it were mine, I'd glue on a dust cap whether it had one originally or not. I wouldn't want the gap getting full of dirt/gunk/etc. and ruining a cool vintage speaker.
Edit: I've many times found dust caps bouncing around between the cone and grill cloth after glue dried out and they came loose. I can't imagine someone would manufacture a speaker without a dust cap, but like I said, anything is possible.Last edited by The Dude; 02-28-2023, 03:45 AM."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by The Dude View PostIf it were mine, I'd glue on a dust cap whether it had one originally or not.
- Likes 3
