Im betting most of you have been thru this one......
Working on a 67 Bassman --loud hum - Volumes on 0 . power tubes in but no phase inverter tube in . The back story= owner was playing and they blew a breaker during practice. Reset and turned on this amp--it went up in smoke.
I found a shorted 6L6 and burnt screen grid 470 . I replaced the 2 470 ohm sc. grids and the 1.5k's at the sockets. new 6L6 tubes now.
Chasing the hum still , I decided to get a re-cap kit for it (electrolytics) . So all those are new---everything in the doghouse is new. Voltages look fine everywhere. Bias voltage looks good . The hum still persists.. This is with Volumes on 0 and NO phase inv tube installed .. just the 6L6 tubes
Checked all grounds . It does have a 3 wire ac cable. Bias cap and resistor are new also. Everything from the Hum pot to the tubes is good.
Im starting to suspect one of the 6 rectifiers (or more) . Checked everything in bias supply ( has the original diode still ) I cant find any resistors way out of spec .
Last thing i tried is clipping in 2 , 100 ohm resistors from pilot light ac to ground = no difference .
Any ideas ???
video---
https://youtube.com/shorts/hBA4EB5BXgI
https://www.thetubestore.com/lib/the...-Schematic.pdf
Any ideas ???
video---
