Hi, the amp was given to me with no speakers. there is a single male 1/4"jack cord split into two female 1/4" jacks. the cabinet is set up for 2 x 12" speakers. In this configuration, what ohm speaker should i use.Thanks
Kustom K150-7
Originally posted by Rws62 View PostHi, the amp was given to me with no speakers. there is a single male 1/4"jack cord split into two female 1/4" jacks. the cabinet is set up for 2 x 12" speakers. In this configuration, what ohm speaker should i use.Thanks
If it is missing, the guideline that I would use is that most all old Kustom amps were designed to work into a 4 ohm load. There are exceptions, but I think if you use 2- 8 ohm speakers you'll be ok.
