I just picked up this amp. It will be my first Kay amp. Usually the Kay tube amps I see are widow maker amps that I pass on. So when I saw the transformers and the description of the tube line up, I made an offer. It was described as 515. It does have a 15" speaker, but when I searched the 515, it's not quite the same. I found the exact amp on ebay but no model given. Only described as rare tremolux circuit. There are reminiscence of a schematic and parts list on the bottom. When I begin cleaning I'll see what I can find. Here are pics.
Kay 515(?) Tube Amp
Originally posted by glebert View PostThe Tremolux on Ebay says it is a 515. https://www.ebay.com/i/174275517544?...4aAud9EALw_wcB
- Likes 2
Originally posted by tigerzilly View Post
I looked at the original schematic and V is hand written over the L.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
And 5U4 is crossed out with 5Y3 written over. Maybe there was another model with same schematic but different tubes. Or they just changed up on the fly and pencilled in the changes.
- Likes 1
So after replacing the caps and installing a grounded power cord, I was bringing up power and I could see signal passing when my power supply tripped as i was reaching 118v. Turned out my PT was shorting. It was running hot and drawing an amp with nothing connected. So installed new PT, ClassicTone 40-18060. It powers up and passes signal. Sounds loud, nice breakup....but....i hear a crackling noise, no trem, and volume goes full by 3. I swapped tubes and speaker, measured volume pots. It's gonna take some more sorting out.
