I've been checking several forums I belong to about harp amps and this is definitely the place to be.
I have several old tube PA's that I have "collected" over the last few years and it's now time to start some mods/upgrades on some of them. I've previously modded a couple of Epi Vjr's (basically Lonewolf mods) with good results.
This is the next amp on the project table:
Some photos are here:masco ma17n pictures by madkatb - Photobucket
(6SL7 plate loads are 100k, cap on screen grid of 6SJ7 is a larger Mallory OD, probably .01? have to remove to read)
So I'm looking for ideas. As a start, I'm thinking three inputs: grid leak, cathode biased and straight into the 6SJ7 (the phono input). But before that I have to try to reform the caps or replace them, replace some of the coupling caps (they aren't suppose to "ooze" are they?), rewire the heaters, finish cleaning the chassis, sort out a better grounding scheme,etc.
As I said I have several of these old PA's so this is just the first step in a long journey...
