Hi
I originally posted about my old tube amp in the guitar amp section, not aware that there was a Harp Amp section (silly me)
Anyway, I think I'm almost ready to start re-building this old baby.
It is a Chandler gramophone amp, circa 1940s, made in Brisbane, Australia. I have stripped it out, thrown out the capacitors and resistors and kept all the iron and tubes. (Before you ask, I meggered the iron - I'm an electrician)
I made a few mistakes when I was tracing out the circuit and luckily, someone pointed me to an Epiphone Electar Zephyr amp, which is almost identical.
My final amalgamated drawing can be downloaded here (its a .pdf) I'd like a harp amp 'expert' to look over the schematic to see A) if it will work and B) tell me any way to 'tweak it' for blues harp. (There are some questions typed directly on the .pdf)
A few of the component values differ on both amps, so I'd also like some advice on which values to go with.
As if I haven't already asked too much of you, I'd like you to look over a second schematic and let me know which preamp circuit would be better for a harp amp. Like I said, the Zephyr and Chandler are almost identical, but the first stage is quite different on both. That schematic can be downloaded here. This drawing also shows an alternative tone / volume configuration which I found on another Zephyr schematic. The original shows the Tone first, then Volume - the alternative reverses this. I wonder how this would affect the amp?
Last questions (for now) (I promise)
I already have a 5 watt single ended amp loosely based (I believe) on a fender 5E3, I believe. It has a gain AND a volume. I find this handy for getting a dirty sound at low volume. Could I incorporate a master volume into my circuit? And how would I do it?
