5F1 rebuild resistor advice needed
The wire wound resistors is normally bigger. Check you have room for them before you buy them.
Thanks for the responses. I did some more research last night and was thinking of getting 5 watt wire wound resistors for both of the power supply resistors. Is there any reason not to go this route?
Thanks again,
Gene
Leave a comment:
½ watt be just fine for most of the resistors. The 10K in the power supply must be bigger. i use a 5 Watt 10K and a 2W 22K
Leave a comment:
Fender used 1/2 watt and nothing near 5% tolerance and many of their amps are still running. Seems like a fine idea to me.
Leave a comment:
I built a 5F1 clone several years back. I did a lot of things wrong because I didn't have access to very much information. This was before the internet so information was not just a click away. I am completely rebuilding the board with better caps and new carbon comp resistors. I looked up the resistors on Mouser's site. I can get all the resistors in 1/2 watt and 5% tolerance that are rated for 350 volts. Are these values right or do I need something different?
Thanks a lot,
GeneTags: None
Leave a comment:
