Originally posted by x-pro
View Post
Traynor Beta 800 testing
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
There is no 5W 2.7k...
At the right of C10 there are 2x 100ohm 1w resistor (R8, R9) between the +65v rail and Q1 collector.
R10 and R11 are 4.7ohm 0.5w between Q1 and Q2 emiters and the ground.
And 2x other 100ohm 1w resistor (R12, R13) between the -65v rail and Q1 collector.
I will swap ZD4 and ZD5 to see if the problem move and repace ZD3 for a new load tested one.
I figure only Q2 will be left at that point.
Or since Q1 is triggered by the negative rail via ZD5, is it this one that regulate the negative rail ?
I'm attaching the complete service manual for the earlier versions. See 'Important' note on pg.9. It's possible Q1 or Q2 may have been damaged.
Suggest you connect the amp boards like x-pro suggested. The bulb limiter may be what is giving you trouble. A variac would be better. Follow the test procedure on pg.9 and 4 of 'SM'.
edit: adding 'SM2' manual containing some other infoLast edited by g1; 08-05-2024, 05:52 PM.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Unconfigured Ad Widget
