Traynor Beta 800 testing
  • #46
    I still cannot adjust the bias with the TP1 and TP2.
    The first part of the circuit is revised.
    The High voltage rails are at +89.5 / -97.5 vdc
    Low voltage rails are at +77.6 / -78.6 vdc
    ZD6 cathode +15.4 / ZD7 anode -15.9 vdc
    ZD9 anode +1.09 / ZD10 cathode -1.39 vdc
    D14 anode 0 / D15 cathode 0 vdc
    There is something odd between the first and the second version schematics.
    They are originally talking about measuring the amperage to adjust the bias, without specifying the test points, look like it's Q11 emitter ?
    Then on the second version they call for a voltages measurment at TP1 & TP2.
    Click image for larger version  Name:	image.png Views:	0 Size:	3.9 KB ID:	1008268Click image for larger version  Name:	image.png Views:	0 Size:	496.7 KB ID:	1008269
    Just dynamicly test Q14, Q16, Q15 and Q17 out of circuit and they were all OK.
    I also recheck Q11 and it's fine.
    I will reinstall this amp board and try to adjust VR42 again.
    • #47
      Quiescent current refers to the current through the output devices. To measure it directly would mean cutting traces to insert the ammeter. So instead, we measure the voltage across their emitter resistors and calculate to determine the current.
      Without looking at the schematic, I would guess that there is 1 ohm between TP1 and TP2. 4mV across 1 ohm means there is 4mA of quiescent current.
      You still seem to have a problem with imbalance of the higher voltage supplies.
      • #48
        There should be 3-4V between the collector and emitter of Q11.
        The amplifier output (at TP10) should be 0 V relative to Ground 2
        • #49
          About the power supply, i've double check everything twice, short of replacing the 6 big filtering caps.
          The power supply feed only one amp board for now and i put a small 2k 2w load resistor on the second amp ps connector.
          What should be the tolerances according to you and who is the possible suspect ?
          Q11 Collector to GND2 +1.69 vdc
          Emitter to GND2 - 1.24 vdc
          differential 2.93 vdc
          TP10 to GND2 0.016 to 0.018 vdc
          And VR42 is affecting the Q11 Collector voltage from 1.64 to 2.2 vdc.
          But the Q11 Emitter voltage do not change.
          I have fixed 0.0002vdc (0.2 mv) at TP1 & TP2
          • #50
            "Q11 emitter voltage does not change."
            This is not good. Check the voltage b-e at Q13, Q19(Q19A), Q21(23/25/27). precisely b-e on their conclusions. (+) probe to the emitter, (-) probe to the base.​
            • #51
              Emiter to Base voltage
              Q13 - 2.34 vdc
              Q19(Q19A) 0.551 vdc
              Q21(23/25/27) 0.100 vdc
              Bias measured at Q11
              Collector to GND2 1.67 to 2.37 vdc variable with VR42
              Emitter to GND -1.09 vdc fixed
              Only 0.0002 v at TP1-TP2
              • #52
                Q13 looks to have an open B-E junction. Voltage drop B-E should not be more than about .7V on a working transistor.
                • #53
                  I've just measure Q12 and all the transistors on the positive rail and they mirror the negative side exept for Q13 wich have an E to B voltage way higher.
                  So i will change Q13 right away.
                  While measuring Q18 and Q18a i found that R95 and R95a are burned (5.7mOhm and 6.6kOhm) will change these too.
                  R96 and R96a are testing good.
                  • #54
                    Good news !
                    The last problem on the channel B was this Q13 and the 2x 1 ohm resistors R95 & R95a.
                    Very surprising, i bought a transistor tester because some transistors were defective even if testing good with a multimeter.
                    In this case the old Q13 was measuring about the same as the new one and was passing the gain, leakage and bias test.
                    The static Vbc and the required bias voltage were a little higher, the gain was half the new.
                    I was measuring Vbe and Vbc with a multimeter and performing the leakage test on top.
                    From now on i will also perform a Veb measurment live on the board because the previous procedure didn't catch the problem...
                    So now it's working, all the TP measurments are in the specs of the manual except the output offset voltage wich is at 0.075vdc when it should be at 0.025vdc...
                    Is this really a problem ?
                    I have music out of this one, proceeding with the channel A !
                    • #55
                      At first try the channel A board's LED did not go ON.
                      I desoldered and double checked the pre-drivers transistors and found Q9 defective (massive c to b leak).
                      I replaced it and now the LEDS go ON.
                      I was able to set the bias to 4mv.
                      The others specs are right on too.
                      The output offset are -13mv for channel A and +16mv for channel B.
                      Got sound and no noise.
                      Next a little burn in...
