This active speaker had an open voice coil woofer and no tweeter output even if the tweeter is fine.
The amplifier board (DM350W+65W) is also the power supply so i verified it first.
All the power rails are fine and both channels are working.
Confirmed solid SD signal line at 4.95 vdc.
Looking at the Preamp board, no "Tweeter Out", this signal should be present at J6 to feed the CN101 "high Input" of the amp.
The "Woofer out" is fine with a strong signal as per the volume.
J6 is the lower white connector on the right side of the pictured board, it's labeled "tweeter out".
This PRE amp board have many differences on the output side from all other schematics i have from Alto.
Without the schematic, it's difficult to follow any trails...
I will begin by removing the J6 connector in order to find and follow a trace...
