Peavey M100 Help!!
  • Peavey M100 Help!!
    Have a Peavey messenger m100 portable powered mixer pa system
    Everthing works input cd, mics, headphones, line out BUT......
    Both Main L and R speaker ouputs do NOT work.....
    Bad power amp??
    Speaker output relays??
    Fuses??
    How could I fix or Test....?
    Please Help....!
    check the speakers first.
      The power amp is class D, and one chip handles both channels.
      Are all the connectors on the power map board on fully?
      The power amp runs on +25/-25VDC - are BOTH present at CN100?
      Between the chip and Q101 transistor is a zener diode DZ101. is there about 5 or 6 volts across it?
