Peavey Mark III Series 260 C
    NTE is a brand of general replacement semiconductors (NTE - NuTone Electronics). They have a large catalog, and you look up your transistor, and it tells you which one of theirs you can use in its place.
    Their part will probably be close to the original, but it is not the original. If it were just one transistor all by itself, I wouldn;t be so concerned. But your amp here is exactly where it matters. When there are two MJ15003 side by side, or two 67376, they have to share current equally, you can;t have one of them hogging the current while its partner idles. The parts also need to track thermally to prevent runaway and proper bias.
    I mentioned earlier that you want two the same on either side, no mixing. The NTE parts would not be the same.
    Not only that, but the NTE parts usually cost three to ten times more than real parts.
      Thanks for the heads up.
        Originally posted by howarda View Post
        Quote:
        never buy the NTE versions of transistors
        What's that about?
        Well...lets put it like this. you go to the tire store and ask for 4 tires size 225/70/15 the guy hands you 4 tires that while are the correct size, are made by 4 different manufacturers, one is a whitewall, one is a truck tire, and 2 are snow tires. yet they all say NTE 225/70/15 on them...get the picture?
        NTE parts are generic. one part number crosses to MANY other part numbers with wildly varying specs. you never really know what you are getting. so for a pinball machine NTE parts are great. but for an audio amp....forget it.
        Zc
          I see
            Replaced the two power transistors and still have the loud hum. All 4 power transistors became extremely hot. Now they are not even warm. 40VDC reading at speaker output. I did note that with the compressor turned on the loud hum is reduced greatly.
              Please DO NOT connect a speaker until you get rid of the DC on the output.
                I checked the two power transistors that I replaced. They read good out of the board.
                  The amp is more than two power transistors, it is a whole circuit. GO back to post #9. Did you check ALL those things?
                    I did check all that previously. I guess I need to recheck now. Is the only true way to check the transistors, to remove them from the circuit board (or at least the base)?
                      You check them initially in circuit with the diode test function of your meter. Note from the schematic if there are low resisyances between any two elements. If they test funny, then remove them and retest out of circuit.
                      ANy time you blow a fuse, all the semiconductors become suspects again. You always need to verify the outputs are OK, an the drivers, and also important is making sure the various resistors havve not gone open.
                        Will do.
                        • #27
                          Sorry to revive and hijack an old topic, but I have the exact same amp with the exact same problem.
                          EVERY semiconductor checks good, with the exception of U2... I can't get a reading with the diode check going from the output to the +/- inputs... not sure if that's the way it's supposed to be or not, but regardless, when I take it out of the circuit, the 40 VDC goes away, but I still get the hum when I do a quick check with the speaker (and by quick, I mean power on for less than a second). Either way, how would this send 40 VDC across the circuit when it's only getting 15 VDC?
                          Something else I've noticed is that when I turn off the compressor/limiter, the 40 VDC goes away, but the hum is still there.
                          It's definitely not the preamp; no 40 VDC coming out of that jack, and I can plug the preamp output into another amp, and it works perfectly fine like there's nothing wrong, and I've also disconnected the front panel and powered up the power amp, but still got 40 VDC out the speaker connectors.
                          Another thing I've found is that when I kill power to the amp, no matter how I have it hooked up or configured, the output jumps to 40 VDC, then trickles down to 1 volt after 60 seconds of being off; this tells me that the huge caps are still working I guess.
                          Any insight?
                          EDIT: I forgot to mention... at points when I don't get the 40 VDC anymore, I instead get 19 VAC, but I still get the noise !?!?!?! I'm so confused.
                          • #28
                            Hi turbo, welcome to the forum.
                            At this point I don't remember what the eact same problem might have been, and I don;t want to read through the whole history to find out. MAy I suggest you just start a new thread for your amp. Most of us are not going to check in at the end of an old long thread to fin d that someone has started a new project at the end of it. And threads are cheap to start...
                            And I have to admit - and I am an old guy, so I am sometimes slow on things - I am usure what you are writing about, when I see sentences that refer to "it" a lot. Let's use part numbers for clarity CR2, Q10, R19, etc.
                            As near as I can tell, you have DC on the output at least some of the time. DC on the output results in loud hum because the severe strain on the power supply exposes its ripple. DO not connect a load to the amp until the DC is resolved.
                            You amp has 42v for both V+ and V-. check them both. The voltage is not critical, it could be anything from 40-45v or even farther off. What matters is both polarities are about the same DC and clean. Now flip your meter to AC volts and remeasure. We are checking for ripple. If yo9u get under a volt or so, that is fine. If one measures 20VAC, then the filter cap is not working - either it has worn out or hte solder has failed that conects it.
                            What does that mean exactly? This is a solid state amp, and as such is DC coupled throughout. The whole point of this amp is to control when the +42 and -42 power rails are connected to the output bus. Even the small parts at the input stages are involved in that process.
                            Pulling U2 makes the amp work? Or just removes the DC?
                            • #29
                              Hate to really revive this one from the dead, but did you ever find a solution for Howard's issue? I had the same thing going on (260c combo), and replacing the two large electrolytics fixed the issue. Having another issue (distortion) though, does somebody have the schematic for the 260c they could send?
                              Thanks!
                              John
                              • #30
                                peavey does, contact customer service at Peavey. I know of two versions, the '78 and the '81. They are VERY similar. Just ask for both.
                                Howard likely solved his problem, but didn't come back to share that.
                                We'd be glad to help you too, but please start a new thread for yours.
