I recently acquired a Simmons DA200S amplifier off Craigslist, and for those unfamiliar with it, this is a pretty cool amp.
It's got an internal 12" sub, for which the bottom of the unit is vented. On the front it has a pair of smaller drivers (5" maybe?) and a pair of tweeters. These are facing slightly apart to accurately project the stereo field -- the idea being that you can plug your stereo drum module into it and play your electronic drum kit, making for a more realistic experience.. depending on how you have your kit panned of course.
Anyway, enough about that. It's a cool amp. The one I got was sounding like shit though, so I opened it up and found someone had stolen the sub out of it and replaced it with a beat up old Kicker 12" woofer, like you would use in a car. Lame. Thanks craigslist. I got rid of that thing and am now on the hunt for a new woofer. But, since this amp is kind of unique, I'm not sure how to determine what parameters would make a driver appropriate for the application. From the user manual I know that the original sub driver was:
12"
8ohm
150w RMS
and that's all. I don't know how I can figure out what an appropriate frequency response would be or whether the relatively small cabinet would be adequate for any particular woofer. It would be great if someone has access to the specs for the original speaker, but otherwise any other guidance would be appreciated. Sorry for the long post.
12"
8ohm
150w RMS
