docSanchez;182882 says:
I have the service manual for the RA-500, which has the same PCB:
hi ya'll, same RA150 model here, powers up, red led's stay on for the 4-5 secs or so,
relay clips, blue led does not come on ... no sound ...
R401/R402 are discolored, they get hot ...impossible to see markings,
the RA500 power supply diagram shows their values at 180 ohms ...
i took one leg out, both measure 470 ohm within a few ohms of each other ... mmmm ...
coincidence ? ... which one is right, the diagram or the resistors ?
anyone with the RA150 service manual who could verify R401/402 values ?
is it possible to find the RA150 service manual online ?
C401 220uF 25V cap was blown, replaced ... C402 ok, very low esr ok, 224uF ok, leakage don't know, have nothing to measure it ...
all caps on this amp are cheap bottom of the line 4th grade chinese Jun Fu ...
considering replacing them all, but first want to find the source of the problem ...
thanks in advance ... hope this discussion helps others as well, the utub videos on repairing the ra150 show nothing ...
