A Rhodes Suitcase Piano I bought in 1989 was my first electro-mechanical keyboard, so I know them inside and out--at least, I thought I did... Mine is the 80W "Peterson" design with dual 40W germanium output transistor modules.
A client recently brought me a 100W Suitcase Piano that had signal dropouts I traced to bad solder joints on the PCB connectors, but I also noticed that, unlike my Rhodes, it made a very loud, annoying thump when switched on. Knowing that this isn't good for speakers, I started trying to figure out what was wrong, but I couldn't find anything. I contacted another keyboard tech and found out that this is "normal" for the 100W version. So, why doesn't this happen with the 80W models?
The 80W Suitcase amps use interstage phase-inverting transformers to couple the driver stage to the output transistors, and, apparently, this blocks most DC turn-on transients from hitting the output stage. The 100W Suitcase amps, however, are completely direct-coupled, so all the turn-on transients go right through to the speakers. Sometimes older technology isn't so bad after all.
The other tech I talked to also noted that he has to replace damaged speakers in the 100W version much more often than in the 80W version, and we both agreed that the direct-coupled version really should have time-delay speaker protection relays, like most solid state power amps have nowadays.
