Hello Sloan,
Could it be a cross over distortion what you mean?
Of course this is hard to tell without a scope ...
I'd check/compare the DC voltages on Q103 & 104, if i'm not mistaken, they are for biasing the power transistors.
Compare the DC voltages over the output resistors too (should be several mV's)
This is indeed a complex amp, the right side of the power amp schematic is the "class H circuitry".
I'd also check/compare the breaking point (DC voltage where it goes to class H ) on L101 & 102 - Q133 & 134.
Just start it up, no signal, no load ... and avoid shorting pins with your probes !!
I wouldn't be surprised if you find a solder failure here, sometimes they are invisible to the eye, but when you bend a component, you can see the solder legs moving on the other side ... 1 component is enough.
Keep me posted, 'cause i'm about to buy a defective one for peanuts on Ebay !!
Grtz
Grtz
