Peavey Eurosys 12 PM problem
  • Peavey Eurosys 12 PM problem
    Hi. I'm new and this is my first posting.
    I'm trying to get the front plate (with the jacks, sliders, etc) off this powered monitor. I've loosened off all the screws and it comes a bit loose but refuses to come off. I don't want to force it in case I break something. I can't see any other screws or catches that I've missed. Can anyone help?
    Thanks.
    Try undoing all the jack nuts, take control knobs off and remove any nuts underneath them, etc.
    If you're still stuck, might be worth calling Peavey UK? The Eurosys range were designed and built in the UK as far as I know. Peavey have a good reputation for tech support.
      Thanks Steve, I'll try that and let you know.
      Cheers.
