Just to discard it as culprit, open Q9's base (lift its leg from the hole) and see what happens.
If the high current through 120r stays, we have to look elsewhere.
If it stops, reconnect it because it looks like Q9 is right (it's showing normal behaviour), so now I'm suspecting a BE short in Q11; because Q9's emitter should be *at least* one diode drop (0.6 to 0.7V) above output rail, which is at ground potential if everything else is fine, because it must turn Q11's base on.
If Q11 were open, you can't have 8V across the 120r resistor and only 0.4V across an 180r one.
To re-check, cut the trace to isolate Q11 base from R30 and Q9's emitter, then we'll see whether Q9 continues pulling so much current.
