For Behringer PMH2000:
The output connector on the back panel of of the chassis jammed and I had to cut through the barrel of the Neutrix plug in order to remove the connector from the PCB mount.
I de-soldered and removed the connector used for the Bridge (which is rarely used) and remounted that on the removed output position, so at least I have two outputs again.
I need to find the correct part number of this connector and/or a source to purchase replacements.
Any help in sourcing this greatly appreciated.
Thank you!
Thank you!
