The power supply caps are in the current path return to common for the amplifier so a stiff power supply has good a low impedance to ground. So how much is enough? Depends on your desired low frequency response and transit response. That is not as simple a question as it sounds, tastes in music change with the state of the society. When I was growing up, there was no such thing a deep bass in recorded music, we did not expect it and did not hear it but we always knew exactly where the kick and bass were driving. We heard the second and higher order harmonics from our 6X9 oval car speakers and portable 45 record players so our brains filled in the sensation of the missing fundamental. Having a limited spectrum to deal with with records, AM radio, hi-fi systems, did not diminish the impact of those classic songs that still sound great today even after being remixed and bottom enhanced artificially. So consider the time in which the Dynakits were available. Amplifying anything that was not in the source material was a bad thing, because it was only noise, so limiting low frequency response, while not a goal usually, no one was concerned that the amps where not flat from DC to Daylight.
For modern recordings which have a lot of signal energy that is outside the range of fundamental notes of the instruments playing, extended response in amps and speakers, at orders of magnitude more power needed to reproduce subsonics, are all part of what is in vogue now. You will have to beef up the supply, for that, and many other changes to handle the deep subsonics convincingly. Lowering the power supply impedance at 20-30 hz will mean a lot more capacitance. It also means pretty high inrush currents to tame to prevent diodes, transformers and primary fuses from self-destructing.
Concerts that want 136db levels in 1960 did it with 100 watts, but nothing was expected through the speakers below about 70 hz. The cost of such a system was a couple thousands dollars when gear was more expensive per level of performance than today when power and low distortion are dirt cheap. Even with the tremendous drop in price of gear, 136db flat down to where people house mixers what to emphasis , 20-30hz is 100-500 times more investment to get that 1.5 octave lower. Even guitar players are seeking more bottom which which presents problems with speakers(some are even open baffle cabinets..and expect LF) and amplifiers to be pretty in distortion from the fundamental notes and all their harmonics and up, when mixing them with subsonics. There are a lot of reasons it is hard to get good tone now, when it was actually easier when a guitar rig only needed to be effective from 100 hz and up.
Did anyone NOT get the beat down pat on first hearing of all those great RB records, or Motown, or Stax, Muscle Shoals recordings? The instruments did not share the same sonic space or spectrum and each stood out. Now, when going to a gig in a club, it seems as if each instrument is trying to suck all the spectrum out of the room. When bass rigs, lead guitar and keyboards are running enough bottom emphasis to overtake the kick drum, something is really screwed up the tone sculpting and arrangements. It also makes vocals unintelligible. Excessive volume is the crutch used by less confident players, those who fear or know they have nothing to say.
So the answer to your question is, as usual, Depends. If you want to reproduce modern digital recordings, you are going to need really stiff low z power supplies at the lowest frequency of concern. But it is a waste if your speakers are not really effective at those frequencies. That presents the worst situation, feeding a signal with high levels of subsonics, into an amp that is needing 90% of its power to reproduce signal frequencies that the speakers can reproduce anyway....the result is both the amp and speaker are being bombarded with energy that is modulating all the reproducible frequencies and making them suck. Full range systems don't make any sense. Use your little SCA-35 for a range of frequencies it is good at, with speakers that are good over the same range and remove all the subsonics from the signal path and route that to the 1000 watt amp and gigantic speakers needed to reproduce the subsonic portion at the same level of perceived level. Or, just listen to old recordings. Or wait around another 20years and a new fade in sound will be all the rage.
