Hi
I am kind of stuck with this baby - shematic attached - it is the 65W Boxer
model. I got it in a state where the big caps were wobbly and when soldered
it worked ok for 2-3 min with headphones. I noticed though that the power
stage is cooking like on full power even when there is no input signal at
all. As I was wondering what to do it blew both fuses and died. Next I found
that TR1 was burned - bought and replaced it stupidly - only to have it blow
again this time burning all 4 power transistors + TR5 + Z1 !
So I bought all parts again (already crying) and this time decided to
proceed gently lest I burn it again. I replaced Z1, TR1, TL072, TR8 (all but
TR7 temp limiter) and with the power transistors T1-4 not installed I turned
the thing back on. Nothing burned this time, rail voltage +-54V and +-15.5V
ok - but I am afraid to install T1-4 on because it still behaves funny and I
think they will burn ..
Basically the LED1,2 at the bias point behave weird and light up for no
reason - with everything uplugged. During this the bases on TR5 TR6 go up to
above 3V and of course they start cooking like hell and I turn it off.
So from start and with gain and vol pots turned down it starts with both
LEDSs not lit up but as soon as I turn up the pots both light up and stay
lit. Again there is no input/speaker during this. The T5/T6 bias and LEDs
behaviour is basically erratic - starts with 1.3 volts only to go way off
and start cooking as soon as I finger anything (e.g R18) or turn pots on.
I tried plugging another amp after R20 and is plays ok also treble/bass
adjusts as it should so looks like the pre amp circuit is working ok in the
audible range anyway.
Any ideas ? I have no scope but I think might be oscillation going on an not
sure where to look next.
thanks
thanks
