actually I was wrong, the wire is .6mm, I wound it up to 27V AC, new current will be higher so no idea yet what DC voltage I will have under full load, hope it's not much over 30V. I made an additional other coil in case I need to install a 12Vfan, I will try to use the existing heatsink if possible by just bolting the chip there and soldering a minimum of components on it, haven't assembled the transformer yet.
will you elaborate on the 'unity gain buiffer' from above - do you mean leave the LEDs but take R20 out ? RV4s the master pot, what about R18 ..
